Question concerning valve spring maximum lift.
Old Jun 29, 2002 | 09:26 AM
JD_Cravin's Avatar
Default Question concerning valve spring maximum lift.
Question 1:
What's the maximum lift for a comp 918 spring?
Question 2:
Is there a spring that provides .650 lift that has the same overall dimensions as the 918 spring? In other words, one that provides that amount of lift and still work with my existing titanium retainers, etc? (I currently have 918 springs)
Thanks for your help!
Old Jun 29, 2002 | 03:46 PM
SteveD's Avatar
Default Re: Question concerning valve spring maximum lift.
I'll see what I can find out about the 918's. I do know that .650 will kill them.
Steve
Old Jun 29, 2002 | 10:23 PM
Richard@WCCH's Avatar
For lifts above .560" a dual spring should be used. The 918 spring is an amazing spring. Being a conical spring it can handle more spring loads than a standard cylindrical wound spring. Some guys are getting by using more lift with the 918s but longevity can become an issue. Two springs will handle the load in high lift applications better than one. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Old Jun 29, 2002 | 10:24 PM
GeorgeC's Avatar
I think they're rated at .625 lift by Comp, assuming that they are installed at the proper height.
You'll be hard pressed to find a 1.25" spring that will handle .650 lift.
Old Jun 29, 2002 | 11:42 PM
JD_Cravin's Avatar
Thanks for your help guys...the lift number I will be reaching is .612, so I figure a spring that can handle .650 lift should be quite safe in this instance.
So a Comp dual spring w/titanium retainers should do the trick.
thanks again,
