LS2 conversion info inside
Old Dec 21, 2008 | 02:38 AM
99blancoSS's Avatar
^^ Yes
Old Dec 21, 2008 | 02:43 AM
t_raven's Avatar
I've been curious about using an LS2 block for a 402 as well. As far as general parts compatibility from gen 3 to 4, I think the crank and rods will work correct? I know an LS2 has the same stroke as the LS1 anyway. Though I don't know if it would be worth the expense to build an stock cube LS2 with an LS1 crank. I'd build a stroker, but it would be nice to know for general knowledge.
Old Dec 21, 2008 | 02:56 AM
the_merv's Avatar
Veteran: Air Force
The Crank and Rods will work without a problem, you could build a Stock LS1 with part of the LS1 Rotating Assembly, I would get it balanced though because of the difference in the LS2 Pistons.
I was looking into goin to an Aluminum Block LS2, and if I did, I would wire up what I needed to, and use my same Rotating Assembly(Crank, Rods, Pistons) that I have now, because it would go in without a problem.
If I went to a LS3 Block, I would get different Pistons, and have the Rotating Assembly balanced again.
Old Dec 21, 2008 | 08:04 AM
camarorat's Avatar
If your using a bare ls2 block and don't want to tear down your current ls motor, or don't have another LS motor here is a list of parts you will need. You can get the entire kit for LS2 or 3 or customize this list for you project from sponsors or other souces.
12570471 LS2 Valley cover 83.06
12594779 PVC tube 9.01
12600325 ls2 front cover
12602548 Coolant crossover pipe 20.24
12602540 Coolant Caps (2) 4.71 each
11588714 Coolant pipe/cap bolts (4) 2.64 each
12615666 Rear crankshaft seal housing
12574293 Gasket for above 14.86
12556127 Bolts for above housing (12)
89060436 Rear Crank seal 13.50
12573460 Oil galley rear plug w/seal 4.39
11588949 Oil plug side (2) 4.71 each
9427693 Water drain plug front (4) 2.64 each
1453658 Trans dowel (2) 2.57 each
11609289 Water Drain Plug - Hex 7.23
12589016 Cam retainer Plate
11515756 Camshaft retainer Plate bolt (4)
12570125 *LS2 knock sensors (2)
12589867 *LS1 Knock sensors (2)
12585546 *LS2 Crankshaft Sensor
12585546 *LS1 Crankshaft Senor 50.00
11515756 Crank Sensor Bolt .43
12586481 LS2 Cam Gear
12556127 Cam gear bolt
12556582 LS2 Crank Gear
12586482 LS2 Timing chain
12588670 Timing Chain Dampener 11.55
12598831 LS2 Balancer
12557840 Balancer Bolt
12595365 Valve lifter Cups (4)
12551163 Valve Lifter Cup bolts (4)
12551926 Water Pump Bolts (6) 2.64 each
ARP 134 3610 LS2 Head bolts LS2004 and newer
ARP 134 3609 LS2 Head bolts LS pre 2004
ARP 234 5608 LS main stud Kit
Prices may or may not be accurate, but are close.
Old Aug 8, 2009 | 04:08 PM
excrider121's Avatar
How do the motor mounts differ from the LS1 to the LS2? Are they the same? What else will need to be done to the chassis after the swap? Does the motor sit in the same place? What about the driveshaft? Can the same shaft be used? Or does it need to be shortened?
Old Aug 8, 2009 | 04:20 PM
mariojmoe's Avatar
Use your Ls1 motor mounts and ls1 driveshaft. Both are identical. My Ls2 in 01 SS should be finished up by Monday or Tues
Old Sep 10, 2009 | 12:08 PM
sscamaro327's Avatar
Hey I have a 2001 GMC. It came with a 5.3 LM 7. Can I drop in a 6.0 LS2 w/o too much trouble?
Old Oct 23, 2009 | 06:10 AM
amkoolaid's Avatar
I have a 99 WS6 that I'm building a ls2 6.0L for. My ls6 intake that fit on a 99 ls1 5.7L will not fit on the ls2, It is to narrow. The 99 ls1 is a Gen 3 engine the ls2 that I have is a Gen 4 engine. My ls2 came out of a 2003 trailblazer SS.
Old Oct 23, 2009 | 07:02 AM
Jeff Smith's Avatar
Good Inform...
Old Dec 24, 2011 | 04:51 PM
GT_EATR's Avatar
I know this thread is old but how much would it cost to swap from a 58x reluctor to a 24x reluctor?
Old Dec 30, 2011 | 06:31 PM
BlackBartZ's Avatar
Default LS2 Swaps
Great info to consider. I have to build me a new plant soon for my 01 Z due to a starter failure and finding this thread gives me some more food for thought. Wondering if anyone can post some updates on lessons learned from performing this swap themselves the past couple of years.
Old Jun 1, 2012 | 09:03 PM
  #32
Jester1225's Avatar
Hi i just purchased a bare lq4 block. I'm dropping it in my 1999 corvette. i'm going to purchase a 408 stroker kit for it that will work with my pcm(24x crank wheel). My cam was intended for my ls1 but i decided just to put everything on this block. I know my top end and everything will bolt right up but as far as seals and timing covers go...will i need to buy the ls2/lq4 style or could i just swap over my timing set from the original motor. I looked for those harness kits that were mentioned in the first post but i couldn't find the "complete" kits, just individual parts. The part #s or a link to them would be much appreciated.
Old Jun 1, 2012 | 09:53 PM
  #33
TJ's Avatar
TJ
as long as the lq4 block takes the cam sensor in the top of the block you can use all of your factory corvette stuff.
Old Oct 11, 2014 | 06:13 PM
  #34
jcmorenols6's Avatar
need some help****
sorry for what im about to ask..im sure its a ftupid question but im comfused a.f.
i have -05 ctvs /ls6/ 5.7
just bought a ls2 6.0L coming out of a s 06 cts v
what exactly do i need to do to get it running how it should..
this talk about drilling knock sensor and adapter is driving me through a maze...thanks a lot for your guys help
Old Nov 16, 2014 | 01:31 PM
  #35
boostwhipped24's Avatar
I have been picking these threads for weeks trying to decide of I still want to mess with this swap
Old Nov 24, 2015 | 11:49 AM
  #36
Corey Browning's Avatar
Originally Posted by jcmorenols6
need some help****
I have an 04 v doing the same thing. Where did you drill?
Old Nov 24, 2015 | 01:05 PM
  #37
thunderstruck507's Avatar
you drill the block where the ls2 knock sensors go...the holes are already there you just make them larger and tap them accordingly.
there is a picture in the very first post of this thread pointing to it's location
