Quick question, pushrod length...
Old Jul 1, 2002 | 04:27 PM
DravenMyers's Avatar
Default Quick question, pushrod length...
For GTP Stage 2 heads with TR224 cam, what pushrod length would I need? 7.350 or 7.400 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Thanks in advance.
Old Jul 1, 2002 | 04:30 PM
AlonzoVersion 1.0's Avatar
Default Re: Quick question, pushrod length...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DravenMyers:
<strong>For GTP Stage 2 heads with TR224 cam, what pushrod length would I need? 7.350 or 7.400 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Thanks in advance.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If they are milled over .15 thous then you need the shorter ones if not then stick with the stock length ones.I could be wrong but someone else want to chime in?
Old Jul 1, 2002 | 04:39 PM
I bought them from Thunder Racing. How can I find out how much they have been milled? Don't all GTP heads come milled at .30 thous? Thanks.
<small>[ July 01, 2002, 04:40 PM: Message edited by: DravenMyers ]</small>
Old Jul 1, 2002 | 04:59 PM
Paul F's Avatar
Our GTP heads are milled .030. Because the base circle of the cam is a little smaller then stock we still recommend 7.400 pushrods with that set-up. You could use the 7.350 without a problem but it will reduce lifter preload causing the valvetrian to be a little louder. Hope this helps...
Old Jul 4, 2002 | 05:47 PM
Thanks for the help guys. Will I have to shim up the rockers, though?
