take both heads off if one is off?
Old Jul 2, 2002 | 08:17 AM
DriveATransAm's Avatar
Default take both heads off if one is off?
i had to take one of the heads off, should i take off the other one too...or will leaving one from the factory and one that i put on screw things up?
Old Jul 2, 2002 | 08:31 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: take both heads off if one is off?
You are just fine leaving one on the motor. Just make sure you use the same thickness gasket on the one you removed (all stock gaskets are the same). Also be sure to use new head bolts, never reuse them.
Tony
Old Jul 2, 2002 | 05:06 PM
any other comments <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 2, 2002 | 06:51 PM
Jason99T/A's Avatar
I can shift faster than you.
Pulling one head is fine. I had to pull the driver's side head on a friend's car when a manifold bolt broke in the head. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Got the head off, drilled and tapped the bolthole and then reinstalled. No problems to date and her car has gone 12.0@112 with bolt ons. (A4 car).
Just be sure to clean the deck surface well and get all coolant from the bolt holes. Replace the head bolts too. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Jason
<small>[ July 02, 2002, 06:51 PM: Message edited by: Jason99T/A ]</small>
Old Jul 2, 2002 | 06:56 PM
anyone know the head gasket and bolt part numbers?
