C5R heads again!
Old Jul 3, 2002 | 03:30 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Re: C5R heads again!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by The Derek H:
<strong>They will bolt up fine to any Gen 3 small block.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I heard from Kaltech that the heads should only be installed in a block with a 4.10"
bore or larger. They recomend a block with a bore of 4.125" that matches the C5R
block. Does that make sense or are they just trying to sell the C5R block.
Old Jul 3, 2002 | 04:19 PM
The Derek H's Avatar
Maybe so. I know they would bolt up but that would be another issue all together. Just contact someone who works with the heads. I'm sure they could be adapted to work. If not you could always pick up a resleeved block or get the C5R block <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 4, 2002 | 12:32 AM
The Emperor Of Darkness's Avatar
Default C5R heads again!
I am just woundering if those could be installed on Ls1(98 in my case) just like ls1 or ls6 heads?!??! is there any other considerations besides the intake?? is there a custom intake that would fit for those??
TIA
<small>[ July 03, 2002, 12:33 PM: Message edited by: The Emperor Of Darkness ]</small>
Old Jul 4, 2002 | 12:42 AM
They will bolt up fine to any Gen 3 small block. All you need is the intake, the new Jesel rocker design, the valves, the valvetrain components, new valvecovers, and a port job. Most shops are recommending running titanium valves in these heads. Give Nick Agostino a call he has a few sets of these on the shelf.
