SLP Springs
Old Jul 3, 2002 | 11:30 PM
2K1SS's Avatar
Default SLP Springs
Has anyone used the SLP springs? here is their ad and Spec's
"Valve Springs, LS-1 (set of 16)
After extensive dyno and track testing, SLP has come up with what we feel to be the "best" matched components for our LS1 Camshafts. These parts can be used with other brands of camshafts but you must verify spring coil bind and retainer to valve guide interference.
LS1 1.250" Performance Valve Spring Set
Designed for camshafts with increased lift up to .600", these chrome silicone springs will allow higher RPM's due to their increased spring rate. When used with our matching chrome moly retainers these valve springs require no head machining to install. Unlike the factory LS1 "beehive" style, SLP's performance valve spring feature a 1.250" straight coil design.
Spring Specs:
105 - 115lbs. @ 1.800"
310 - 340lbs. @ 1.200" "
What do you guys Think??
