Comp Cam degree question, please HELP
Old Jul 6, 2002 | 03:50 PM
Operations's Avatar
Default Comp Cam degree question, please HELP
My new Comp Cam is ground with a 4 degree advance for an "improved streetablity".
The card with the cam said to degree the cam at 110 degree intake lobe centerline (ILC)
To achieve this 110 ILC, I have to retard the timing from the stock marks 7 degrees.
Is this common to adjust it this much?
Or does setting the timing 110 ILC negate the 4 degree advance built into the cam?
Hope you guy's can help. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Jul 6, 2002 | 06:47 PM
Carlitos's Avatar
Default Re: Comp Cam degree question, please HELP
Install your cam "dot to dot". You'll be OK.
'Los
Old Jul 6, 2002 | 10:33 PM
GeorgeC's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Carlitos:
<strong>Install your cam "dot to dot". You'll be OK.
'Los</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ditto... Sounds like you're describing a typical 114lsa cam. With the 4 degrees of advance ground into it, the intake centerline should be 110deg. if you install it "dot-to-dot."
