Internal motor question???
Old Jul 7, 2002 | 02:30 AM
blackLS1's Avatar
Default Internal motor question???
What does it mean when people refer to a 90 deg motor or 60 deg motor? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 7, 2002 | 04:48 AM
pkmoose's Avatar
Default Re: Internal motor question???
it is the angle of the pistons when attached to the crank sitting in the block. If you look at the engine from the front, draw two lines, both starting at the crank, and going out towards the pistons, on the same line that the piston travels. For example, a Porsche or VW has opposing pistons, you could say it is 180 degrees.
hope that helps <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 7, 2002 | 11:42 AM
blackLS1's Avatar
Thanks man.I kinda thought thats what it was but wasn't sure.I wanted to ask to be sure. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
