More Raging 230 results...on stock heads!!!
Re: More Raging 230 results...on stock heads!!!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Smoke_ur_5.0:
<strong>The fuel and timing are close to stock but not quite and this is the particular grind we use. There are actually two verions of it. One of them is a little more extreme than the other and this car is one of them along with my formula. It specs at 230/230 .592/.592 110lsa. The other that is used is a little milder at 230/230 .572/.572 111lsa and is the one Gator uses. Gators idle with the smaller cam does a little better than the bigger cam.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Are either of the 2 making about the same power, or does one edge the other out but a few hp? Essentially, which is better?
Damn you people. Everytime I read a thread like this, it makes me want to buy a cam.
Scott
trying to get my Mustang running, but it is awful hard to
Scott
Sorry if I missed this info but what springs are being used with the .592? I'm guessing the 918s with stock heads.
What kind of power difference between the two different lifts?
Would you consider this capable of being a daily driver?
Thanks
Andy <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Thanks
<strong>It specs at 230/230 .592/.592 110lsa. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What do you think this cam would do on a 114 LSA?
Chris, yeah there's 4 degrees in the smaller one and 0 in the bigger. The bigger one was more for ported and milled heads and the smaller for stock heads. MrRamAir wanted to use the bigger cam since he is getting heads soon..worked very well. Don't think there is really too much difference in power between the two cams though.
The smaller cam peaked at 6400rpm on Gators car and the bigger peaks around 6600rpm on MrRamAirs car. The bigger on my Formula with heads heads peaks at 6450rpm.
These cars are driven almost everyday and we are all using 918 springs. No problems yet.
<small>[ July 10, 2002, 12:28 PM: Message edited by: Smoke_ur_5.0 ]</small>
you would have to spin it to the moon! with my 111 LSA it peaks at 6400 and the 110 peaks around th same. i know of 112's that peak around 6600! be ready to buy a new longblock! this cam is not for the feighnt of heart, but it does idle pretty decent with programing!
Gator is right--you'd have to spin that thing a lot higher than a stock shortblock will handle.
It is a rowdy cam. Nice power throughout the curve, but you really have to spin it.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gator's 99TA:
<strong>you would have to spin it to the moon! with my 111 LSA it peaks at 6400 and the 110 peaks around th same. i know of 112's that peak around 6600...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I wonder about that. I think the MMS 229 cam was on a 114 or 112 and did not peak as high as 6600. One of the Raging cams had zero advance, so if 4 degrees of advance were added, it could come up 1-2 degrees of LSA and probably hold the powerband to the same rpm peak.
