6.0 iron block useres
Are you running a 6.0 block and having cooling issues? Did you get it bored, what size or are you still running the 4.0" bore?
John
Moving to internal engine section.
Shane
i don't think a .030 over bore will affect cooling much , not even more than that i think.
i guess my problem stems from the fact that an iron block dissapates heat much slower than aluminum , thus heating up more.
it just rained here tonight, so i took the car for a dirve in the rain. earlier that day the car would over heat with the AC on going down the highway with outside tems around 110, when i went out in the rain the temprature was much cooler ( about 90 ish) and there was the mist from other cars to cool things down even more. my temps while driving with the AC on this time were below 200 all the time.
this leads me to belive that the radiator is running at it's full capacity in the heat.
guess it's time for a be cool unit!!
will post results when i get it in.
Also, you can wire up the fans to a switch so that they run all of the time.
Scott
<strong>hey trace , you don't have a blower on your motor do you ?? are you still using the stock fans??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do you have a ATI kit on your car? If so it may run a little hot with the single fan when the A/C is on with real hot ambient temps. The radiator should help.
John
