Heads and Cam -- Post your info
H/C make/stage:
Head Specs:
Cam Specs:
Dyno Numbers (and location):
Best track time (street/radials/nittos) & location:
Best track time (slicks) & location:
Major Mods (non std):
Comments:
H/C make/stage: ARE stage II
Head Specs: 2.08/1.60
Cam Specs: 226/234 554/575 112
Dyno Numbers (and location): 395rwhp/386rwtq @ cartek
Best track time (street/radials/nittos) & location: None yet
Best track time (slicks) & location: No slicks
Major Mods (non std): LT headers w/offroads, ported TB, ported LS6 intake, RAM clutch, full exhaust
Comments: Why the $#@% did I pay all this extra money for a setup that produces less power than a cheaper setup? Big giant valves, big cam, lots of bucks, less power than most other stage I equivalent setups. I would think it was just my setup/car, but Ive seen now 5 others with similar ARE setups and crappy dyno nymbers (all under 400rwhp). I am not a happy camper.
<small>[ June 19, 2002, 08:42 AM: Message edited by: ezss ]</small>
H/C make/stage:
Head Specs: MMS stage 2x (5.3L)
Cam Specs: MMS 229v2.1
Dyno Numbers (and location): 435/400 (MMS dyno)
Best track time (street/radials/nittos) & location: Who races on street tires?
Best track time (slicks) & location: 10.98/122 @ Carlsbad Raceway (by San Diego, CA)
Major Mods (non std): ~150# weight reduction, TP4400 stall, EWP, Burger ram air
Comments: Overall its a great street/strip setup. Idles smooth@950rpm, doesn't stall, and makes good power.
<strong>Don't worry about dyno numbers. Some claim numbers like yours with stock heads, manifolds and just a cam. How good does it run ??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Seems strong, but Ill know more this weekend. I couldnt help but notice that you have an ARE setup and dont have dyno numbers or track times in your sig. Coincidence?
Anyhow, thats why I put the post up-- I want to see both from as many people as possible. So come on people! Lets see what they look like! I want to see low and high results both.
Dyno Numbers (and location): 365 on a mustang dyno.
01-A4 stock converter and stock manifolds. Corsa,lid,tuning.
Head Specs: 2.08 / 1.60
Cam Specs: 224 / 224 .581 / .581 114
Dyno Numbers (and location): Not yet installed, but exhaust numbers are 342HP@354TQ RW
Best track time (nittos) & location: 12.90 @ 111 with just Grot's, Corsa, Lid and one bitchin POS clutch at Mid Michigan Motorplex.
Major Mods (non std): 1-7/8" Grot's, Catted Y, Whisper Lid, Corsa
Comments: Just waiting for another week or two before the install. Keeping my fingers crossed!!
<small>[ June 18, 2002, 11:14 PM: Message edited by: derty ]</small>
Cam Specs: T1
Dyno Numbers (and location): 418.9 RWHP 403.9 RWTQ with 4.10's and no tunning
done in West Palm Beach Fl. in 94 degree Heat
Head Specs: GTP S2 5.3L heads milled .040 (2.02 valve)
Cam Specs: 232/232 .574/.574 112
Dyno Numbers (and location): N/A
Best track time (street/radials/nittos) & location: N/A
Best track time (slicks) & location: N/A
Major Mods (non std): All boltons, Dynatech stepped headers, 9" ford with 4.71 gearing
Comments
roject underway...will have dyno numbers and ETs ASAP - cam 226\234 .554\.575 112
- heads 2.08 x 1.60
dyno- 414RWHP/387RWQT (done a local dynoshop by Rapid Motorsports)this was through a 12 bolt with 4.10s and with my chrome 17x11 ZR1s with 315s
-no new times yet
-old set-up had about -50 RWHP and went 12.6@111MPh with a 2.260ft with stock gears, stock clutch and on not so good F1s, oh and a track with no prep.
MODs- RAM VDS clutch, custom 12 bolt with 35 spline axles and 4.10s, BMR SFC, lower control arms, LS6 intake, SLP 85mm MAF, ported TB, SLP cold air induction, whisper lid and K&N, Grott headers, off-road y-pipe, LM exhaust, custom tuning by Ed wright, chrome ZR1s- 17x9.5(275-40-17 front) 17x11(315-35-17 back).
Remember EZss- dynos really don't mean ****, its the track that will tell you the truth. I have seen cars that on the dyno are great but suck at running the numbers- oh Supras come to mind-except for a few.
<strong>ARE stage 2 H/C
- heads 2.08 x 1.60
-no new times yet
Remember EZss- dynos really don't mean ****, its the track that will tell you the truth. I have seen cars that on the dyno are great but suck at running the numbers- oh Supras come to mind-except for a few.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do you have a dyno graph you can send me/posted? I notice the torque on our cars is the same, but you have ~20rwhp on me. Mine peaks at 6500 and then starts to drop off.
Head Specs: stock
Cam Specs: 224/224, .581"/.581", 112 LSA, 2 degrees of advance ground in
Dyno Numbers (and location): 361 RWHP with open cutout and unlocked converter, 379.9 RWHP with open cutout and locked converter; first dynoed at what used to be FASTech in Garland, TX and backed up at Speedworks in Lewisville, TX
Best track time (street/radials/nittos) & location: haven't run it at the track on radials
Best track time (slicks) & location: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight & 1,102' D.A. run at Texas Motorplex May 18, '02
Major Mods (non std): FLP LT's and ORP, 3.73's, Ed Wright tuning, Yank PT4400 converter, ASP crank pulley, free mods, other little stuff
Comments: I'm MORE than pleased with the performance of this setup! I swapped the cam and converter (from Vig 3200 to Yank PT4400) at the same time, and they work VERY well together. I'm amazed at how well the car runs for a street raceweight with stock heads. More than anything, I was shocked with just how streetable the cam is. It has a nice lope at 825 RPM, and it doesn't surge, stall, etc. with the a/c off. I keep it at 825 so I can hear the cam. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I set it at 900 RPM if I'm going to run the a/c, and everything is great. I'm shooting for 11.40's with stock heads and a raceweight of 3,450+#. I plan to add a set of heads over the winter and chase some 10.90's.
Head Specs: 2.02 1.57 5.3 L heads
Cam Specs: 226/234 112LSA
Dyno Numbers (and location): 385RWHP and 439RWTQ ARE's dyno
Best track time (slicks) & location: St Thomas, 100' DA 1.79 sixty (spinning)
11.78@122.60mph
Major Mods (non std): bolt ons, heads and cam, headers, 200R tranny, TP 4400 12 bolt etc
Comments:
Package works great for me, I am going back to the six speed so I will probably pick up a little mph. ARE's service has been fantastic
Cheers,
Chris
<small>[ June 19, 2002, 09:06 AM: Message edited by: Chris ARE 360 ]</small>
<strong>Taking a survey, if you have em (or even just a cam) post the following:
H/C make/stage: JPR S2
Cam Specs: th224
Dyno Numbers (and location): 388RWHP 432 RWTQ (w/o edit)
Best track time (street/radials/nittos) & location: Soon
Best track time (slicks) & location: Soon
Major Mods (non std): TH400 w/400Unlocked vert headers 3.73's boltons.
Comments:</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">feels awsome it will see 400 440 before joe is done.
Don't forget, no dyno is the same. I asked Mike @ Rapid about all the guys posting 400+RWHP with a cam like the 224 cams and such. He said he has installed many of those cams and only gets 350-360RWHP. He said the dyno he uses (dynojet) does tend to be a bit on the low side, but not 50-60RWHP off. Some tuners play the number games. All they have to do is punch a different rear gear ratio(2.73 rather then the real 4.10)and you will get a higher rear-wheel HP. Anything on the net I take with a grain of salt. Don't believe everything you read. I am not saying everyone is lieing but merely I only fully believe HP numbers when I actually see the car go down the track.
XE-R 224/224 114 cam
Bolt-ons, 12 bolt w/3.73s, YTP 4200
Dyno:
locked: 378HP @ 6100, 362TQ @ 4800
Unlocked: 365HP @ ~6300, 485 TQ @ 3100.
Track time in sig.
Head Specs:Stage2 2.02/1.56 heads milled .030
Cam Specs:221/221 .558/.558 114LS (for now)
Dyno Numbers (and location):435hp/410tq (MC Racing dynojet)
Best track time (street/radials/nittos) & location: Running on street tires?..HA!
Best track time (slicks) & location: 11.31 at 122.38mph (1.56 60 foot time) at KCIR
ynatech headers w/OR ypipe, cutout, lid, ported TB, LS6 intake, ASP, Mcleod, Moser 12 bolt (4.10's), MT ET drag 26x10 w/skinnies on prostars.Comments: All around awesome performer! Over 10 miles on the heads and 18k miles on the cam..don't have a problem driving it 600 miles round trip to my favorite track to run it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ June 19, 2002, 10:51 AM: Message edited by: Smoke_ur_5.0 ]</small>
Head Specs: Stock valves
Cam Specs: comp 218/224 .528/.535 112 lsa
Dyno Numbers (and location): 415/392 SAE on JD's Dynojet
Best track time (street/radials/nittos) & location: 12.22@116 w/ 2.0 60' on nittos at etown, went 118 with Joe driving (2.1 60')
Best track time (slicks) & location: n/a
Major Mods (non std): ls6 intake, flp's w/ orp's, ported tb, loudmouth
Comments: Nice daily driver setup w/ stock gears and weight, idles very well, no driveability issues. Just need to 60' the car
<img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Head Specs: LS1 Head, milled 0.030" with stock valves, and 63.7 cc combustion chambers
Staic Compression Ratio: 10.53:1
Cam Specs: Hammer/Andy cam 222/222 .566/.566 112 LS
Before (heads/cam/header)- 310.0 HP / 317.7 Torque
After (heads/cam/header)- 388.7 HP / 384.9 Torque
Best track time (street/radials/nittos) & location:8.25@92mph on a totally shot stock clutch smoking as I drove down the track. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> I have a clutch ready to go in. That was about 2500 Density Altitude
Major Mods (non std): Heads, cam, mac headers with off road y-pipe, whisper lid, hpp3, flowmaster 1-chamber muffler, LS6 intake manifold, Zed cutout
Comments: I need a clutch. It started slipping after a few track passes on the stock clutch. That really sucks.
I have all the details on my website. www.installuniversity.com I could be leaving something out.
Eric
<small>[ June 19, 2002, 11:02 AM: Message edited by: wizkid ]</small>
