ok going with the 422 but which..
Old Jul 10, 2002 | 01:52 PM
MrWS6's Avatar
Default ok going with the 422 but which..
ok Thanks to your guys help I have gone with the 422.. Now I am gettin a 12 bolt put on and only go to the track maybe once a month...what are your thoughts on gears..I was thinking 3.73 for an m6 so I had a little top end back having 4.10's now. Also how aggressive of a cam should I go with... I am goign with thunder racings just not sure how large to go. Lastly what do u think the car will run with my mods done when its all done in two weeks:with and without juice
422 motor
Stage 3 heads,
Thunder cam,
Flp long tube headers,
magnaflow x pipe no mufflers or cats
ported maf
Cags
Throttle bump stop Mod
Pro 5.0 short throw shifter
moser 3.73
moser 12 bolt
Hal shocks adjustable
convo pro wheels with et streets
ls6 intake
removed back seats, spare tire, jack, light weight seats,
Old Jul 10, 2002 | 01:57 PM
MrWS6's Avatar
Default Re: ok going with the 422 but which..
o sorry 150 shot of juice
Old Jul 10, 2002 | 01:59 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You're going to need a LOT more than a 26" ET Street to hook up the power of a 422! It will kill those tires off of the line. You need a 28" slick, and I'd also go with 4.10's. Which Thunder cam are you referring to? No matter what, the popular ones are too small for that size of an engine. You have a lot more volume to fill with a bigger bore and longer stroke. I'd go with something in the mid-to-high 23x duration @ .050" if you're looking for something somewhat tame, and I'd look at cams over 240 degrees of duration @ .050" if you're wanting more HP. Are you not going to run cats or a muffler? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> You'll reconsider that after you realize how loud the car is going to be. Be sure that the x-pipe you list is 3" off of the headers.
Who's building the engine? I'm not going to comment on what it would run because we first have to see who's building it, which cam you go with, gearing, etc. Also, I have no idea how well you can drive at the track, what the conditions will be like, how much the car will weigh, etc. There are way too many variables to consider to just pull a # out of the air.
<small>[ July 10, 2002, 02:01 PM: Message edited by: Trevor D ]</small>
__________________
Old Jul 10, 2002 | 02:12 PM
MrWS6's Avatar
to answer some ?'s mti is building the motor, figure gearing being 4.10's, the x pipe is 3 inch, and as far as the track figure average driver weather and car weight 3450 with driver
