Help! No compression in #4
Old Feb 18, 2007 | 11:27 AM
TXSilverV's Avatar
Bad Trader Warning!
Question Help! No compression in #4
Wanted to see if you guys could help. I have no compression in #4.
We pulled the valve cover off and found a broken spring. Replaced the spring and still no compression. Checked the push rod (only #4) and it was fine. What do I check now? Do I need to check all the pushrods? This is a LS6 with heads and cam. I'm new to this and just learning. How far should I go by myself?
Old Feb 18, 2007 | 12:24 PM
92zcamaroperson's Avatar
if the spring broke your valve might of dropped and bent
Old Feb 18, 2007 | 12:34 PM
JPH's Avatar
JPH
bent valve?
Old Feb 18, 2007 | 02:27 PM
SPRAYED 01's Avatar
You have a bent valve. I just went through the same thing. Take the head off and send to a machine shop. They will most likely replaced the bent valves and clean up the seat if not to damaged. It happens, most likely not the end of the world.
Old Feb 18, 2007 | 04:36 PM
TXSilverV's Avatar
Bad Trader Warning!
Thanks for the help guys!
