Loud Squealing Sound at Idle
I recently installed a H/C pacakge and replaced all the hydraulic lifters and all idler pulleys while the car was down. The car was dyno tested and driven abot 200 miles with no whistles or loud squeals. I had the stock intake and throttle body for my 2001 vert and went with the FAST and LS2 setup per my tuner's recommendation.
Any ideas / suggestions welcome.
Thanks for your time.
I replaced all idler pulleys, belts (both A/C and serpentine) when I did my H/C package about 200 miles ago. I switched to the FAST 90 because my H/C did not make the full HP it should have and we determined the car was restricted. I also installed a set of Kooks and asociated cats / x-pipe.
I have never encounterd a vacuum leak that makes this loud of a squealing noise. I thought maybe the FAST intake has some pecularities that you have to address to settle everything in?
Still looking to determine what is the cause.
I am pretty certain this is your problem.
J.R.
