Is the stroke the same on 6.0 liter and 5.7 liter
11 Second Truck Club
Can I use my crank and rods out of my 5.7 in a 6.0 block also will everything else bolt up ok.
LSxGuy widda 9sec Mustang
Re: Is the stroke the same on 6.0 liter and 5.7 liter
Same stroke, just different crankshafts. The 6.0L crankshaft is not gun-drilled through the middle like the LS1 crank. You would have to have the reciprocating assembly rebalanced also because of the different piston weight--- 3.898" bore versus 4" bore pistons.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2bseen:
<strong>so I can not use my lunati crank out of my ls1.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I didn't see that you had a 382, I thought you were talking about the factory stuff <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Yes that crank and rods will work, just make sure to have everything rebalanced since the bigger bore pistons will be heavier.
