sealing up the engine
Old Feb 18, 2007 | 06:24 PM
Timonator's Avatar
Default sealing up the engine
I'm going to change the rod bolts,oil pump and timing chain on my 74,000 mile shortblock.My question is:how critical is it lining up the front and rear covers and oil pan?Do you need the kent moore kit?Is there a simpler way?
Old Feb 18, 2007 | 06:59 PM
Cop Car's Avatar
um.. just bolt everything on and follow torque specs and sequence
Old Feb 18, 2007 | 07:40 PM
slow95z's Avatar
i just lined it up by hand and made sure to get the covers on as best i could and i have yet to have a leak.
Old Feb 18, 2007 | 09:06 PM
Grimes's Avatar
from what I hear, you should leave the front cover bolts loose until you get the damper on. this will center the entire front cover properly. then tighten down the cover.
Old Feb 18, 2007 | 09:15 PM
Blk97WS6's Avatar
thats what i did. No leaks what-so-ever.
Old Feb 18, 2007 | 09:25 PM
frodo84's Avatar
Yeah, the rear cover is a bigger deal for sure...
Old Feb 19, 2007 | 07:07 PM
Timonator's Avatar
So,anything special on the rear cover?
Old Feb 19, 2007 | 07:39 PM
Cop Car's Avatar
have to make sure you dont mess up the rear main seal.
when you get a new seal, keep the plastic ring that goes inside it. wrap some tape around it to make it bigger and put it back in the seal, it stretches it out.. keep doing it untill the rear seal goes on there real easy
 Michael S. Palmer
Old Feb 19, 2007 | 07:47 PM
DaddySS's Avatar
For rod bolts, chain and pump why do you need to take off the rear cover?
Old Feb 19, 2007 | 07:53 PM
Timonator's Avatar
I guess i really don't.I just thought i would change all the seals as long as I was there.
Old Feb 19, 2007 | 08:06 PM
DaddySS's Avatar
Understood, but unless you're also pulling the trans, the rear cover and seal are not on your way.
Old Feb 19, 2007 | 08:21 PM
Timonator's Avatar
The engine is out of the car.
Old Feb 20, 2007 | 01:19 AM
Cop Car's Avatar
i wouldnt mess with the rear seal then.. if there isnt a problem you risk creating one
