Comp 918s V's LS6 springs..... Anyone know the specs?
Anyone know the difference in the springs. Seat pressure, etc etc. Gimme reasons why ones better than the other for saaaaaay .........an ASA cam <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Re: Comp 918s V's LS6 springs..... Anyone know the specs?
I believe the 918's have a slightly higher spring rate and will handle more lift.
I will look up the specs after lunch.
try a search on LS1info.com
I was told by one of the sponsers on thi board the the ramp rates of most of these cams (after market LS1)are to aggressive for the LS6 springs(even the 02's). Keep a eye on the seat perasure I THINK the 02 LS6's open preasure is low. some were around 109? (I think). Also,the last time I checked the price they were around $198.00 a set.
Comp 915/918 --------915--------- 918
Installed Load: 105 lbs@1.800"-- 130 lbs@1.800"
Open Load: 293 lbs@1.200"------- 318 lbs@1.200"
Spring Rate: 313 lbs/in ---------313 lbs/in
Coil Bind Height: 1.085" --------1.085"
Outside Diameter: 1.290"/1.060”- 1.290"/1.060”
Inside Diameter: .885"/.656”-----.885"/.656”
Retainer: TI772/Steel 77---------TI772/Steel 774
Part # 26915-16----------------- 26918-16
Description GM LS1 Spring High Load Spring
<small>[ July 12, 2002, 12:07 PM: Message edited by: 2K1SS ]</small>
