Anyone using a flat solid lifter??????????
Old Jul 15, 2002 | 07:49 PM
BADZ's Avatar
Moderator
Default Anyone using a flat solid lifter??????????
If so, what is the lash set at during cold temps????? Does it expand and if so by how much @ hot temps???
Thanks...
<small>[ July 15, 2002, 08:56 PM: Message edited by: BADZ ]</small>
Old Jul 15, 2002 | 09:19 PM
Will Race 4 Food's Avatar
Default Re: Anyone using a flat solid lifter??????????
Didn't know that you could get that...
Does someone make a solid (non-roller) lifter for the LS1?? For class racing here, there's a class that would fit in..
Cheers. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 15, 2002 | 09:29 PM
BADZ's Avatar
Moderator
I was asked that earlier today but I was not sure that any of you guy's were actually using this type of lifter...So I guess its a no but if so then we might have someone to start making them for our ls1 application... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ July 15, 2002, 10:54 PM: Message edited by: BADZ ]</small>
Old Jul 15, 2002 | 10:50 PM
ChrisB's Avatar
Are you talking flat tappet - if so, why? Roller solid lifters are superior for pretty much all aspects (lobe agressiveness, cam life, street longevity, etc.)
If you are talking the mushrom style lifter bottoms they are a race only application?
Chris
Old Jul 15, 2002 | 10:58 PM
BADZ's Avatar
Moderator
Yes, I was talking about them, is there a big difference and what about cost? Can the flat tappet lifters have the same variables as what you listed? How about a raduis composite lifter? Like this one?
http://www.schubeckracing.com/contact.htm
Old Jul 16, 2002 | 01:22 AM
ChrisB's Avatar
Flat tappets are pretty much inferior to roller lifters in almost all ways - no reason to run a flat tappet.
The radius lifters are what I was calling mushroom lifters. They do allow for better high rpm use, but I would probably be tearing down the engine 2-3 times a year with a setup that required those. Unless you are turning much over 8000-8500 solid roller is the way to go.
chris
Old Jul 16, 2002 | 06:18 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ChrisB:
<strong>Unless you are turning much over 8000-8500 solid roller is the way to go.
chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ChrisB,
Are you suggesting by that comment that a solid roller set up is not the way to go over 8000-8500 rpm's??
Cheers <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 16, 2002 | 09:13 PM
ChrisB's Avatar
Doh, that read wrong. I meant I wouldn't even bother looking at the mushroom or other more exotic lifters unless I was turning a minimum of 8500.
Chris
