Fuel Pump for 98 LS1 Z28
Old Jul 16, 2002 | 01:10 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: Fuel Pump for 98 LS1 Z28
Just install a Walbro 255 lph intank pump. It'll flow more and cost less than a stock one will. The one I installed in my T/A was labeled as a BBK. Just be sure to get some fuel injection hose to connect the pump with. I'd get ~14" to be sure, then you can trim to fit once you have it out of the tank. Also, be sure that you have the filter sock out of the way so it won't get hung on the float. I did that, and we had to drop the tank again. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
__________________
Old Jul 16, 2002 | 01:31 PM
DanZ28's Avatar
http://www.racetronix.com/
Old Jul 16, 2002 | 03:29 PM
Sears's Avatar
!Dial-up Director
If you want a Plug and play setup then the Racetronix is a NICE setup. Tim98TA and I installed this in my car and is an excellent product. It comes with an independent wiring kit to boost the voltage to the pump ( more flow ). Them pump is a high pressure 340lph Walbro is a custom billet housing.
Justin
Old Jul 16, 2002 | 04:00 PM
steve's Avatar
moving to bolt on section
steve frank
Old Jul 17, 2002 | 12:57 AM
Daniel Rivers's Avatar
Default Fuel Pump for 98 LS1 Z28
Anyone know a part number, and where I can get a fuel pump for a 98 LS1 Z28? Thanks for any help. <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
