Will Crane's Ford rocker shims work with our heads?
Old 07-18-2002, 03:31 PM
MDL-01C5's Avatar
Default Will Crane's Ford rocker shims work with our heads?
I've looked everywhere--even under God's shoe, and couldn't find anything that looked like what I need to use to raise my rocker shaft up .030--
the Ford pedestal mount shims look like the may be usable--but I'm not 100% confident that they'll work...
I have to put the car together this weekend, and I must have shims to do it...(the valves were recessed 30 for clearance issues--before you ask)
Please, any advise would be greatly appreciated--
Old 07-18-2002, 04:37 PM
TrahnZam WS6's Avatar
Default Re: Will Crane's Ford rocker shims work with our heads?
I have heard of guys using rocker shims from some mustang source to set the valvetrain up correctly with comp R lifters. Also Craig at GTP can machine you some shims.
Old 07-18-2002, 05:44 PM
JP98SS's Avatar
MMS has shims. I have a set laying around if they don't have any in stock.
Old 07-18-2002, 05:57 PM
H82BBad's Avatar
I would think you could get any .030 shim from a machine shop (Like the kind used to shim up valve springs) and trim them if needed.
Brent
Old 07-18-2002, 09:04 PM
MDL-01C5's Avatar
Thanks for the advise, guys--I went ahead and ordered the shims from Crane, since I need them by Sat, and I knew I could get them overnighted from them quick...
I checked with a few guys here in town, but they gave me the runaround, so, if the Fords don't work, I'll get back with you to find the right ones
Thanks again, and I hope I'm writing to you next with a functional, and most importantly FAST, C5 <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
