iron block 408 clearance?
Old Feb 20, 2007 | 10:25 PM
454SuperSport's Avatar
Default iron block 408 clearance?
any clearance issues when using callies crank and compstar rods? i've searched but can't find a straight answer. any grinding on the block necessary? i know about spacing out the windage tray with washers, is that it?
Old Feb 20, 2007 | 10:27 PM
justin b's Avatar
good question,im planning on building one too,also whats the best setup for 408?crank,rods,pistons?
Old Feb 20, 2007 | 10:36 PM
AmericanMuscle313's Avatar
I used Compstar rods and a 4.00" Eagle crank for my 408 (Iron block) build. I didnt have any clearance issues. I believe the Compstar 6.125" rods are designed with clearance in mind for a 4.00" stroke
Old Feb 21, 2007 | 04:15 AM
racer7088's Avatar
Thumbs up
You shouldn't have any clearance issues with the Callies Compstar parts at all.
