How much do I charge?
Old Feb 20, 2007 | 11:20 PM
Camaro Rick's Avatar
Default How much do I charge?
I've got all my stock parts laying around from my head/cam swap. All with 50k on them. I didn't want to post anything in the for sale section yet since I have no idea what my stuff is worth. Could you guys help me out with how much to charge? Everything is in good working/mechanical condition. (with exception of one item) I have :
-00' stock cam (198/209 .500"/.500" LSA-119.5)
-Oil pump
-Timing Chain
-LS1 Intake manifold
-lifters
-pushrods
-241 casting heads (one combustion chamber/valve seat+valve slightly damaged on cylinder #7 - repairable)
-stock valvesprings
-brand new set of yellow ls6 springs.
-stock exhaust manifolds/Cats/Y-pipe
...That's as much as I can recall having at this point.
I'm also currently attending classes at UTI in Norwood Mass. Last week my instructor helped me set up a degreeing station so I verified the cam duriation and lift manually. Cam will be sold with sheet of actual lift/duration degrees.
Thanks guys.
Rick M.
Old Feb 21, 2007 | 12:43 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would take your stock cam for 20$ shipped.
