Are Perimeter valve cover gaskets same as Certer Bolt gaskets ?
98s use perimeter valve covers....
Do these use the same gaskets as the ones used on the 99 and above center bolt valve covers?
If not, anyone know the P/N for the center bolts gaskets?
Thanks,
Ron (98 TA)
Thanks,
Ron (98 TA)
"Are Perimeter valve cover gaskets same as Certer Bolt gaskets" ?
No, I have no idea what "Certer" bolt gaskets are.
I just can't type tonight! <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
nope they're different. sorry but i can't help you with the part #.
when installing the new gaskets , i recomend cleaning the valve cover with solvent. or better yet drop it in the dish washer . this gets the oil out from the groove and insures that the gasket stays there.
George...
I was given P/N 12560696 for the 98 perimeter bolt valve cover gaskets.
You have a different number.
Could my number be for the center bolt gaskets?
Ron,
Ron,
Ron, Dug here. I ordered my valve covers from valvegod, and he's supplying the gaskets as well . . .
- Dug
- Dug
