Most duration with stage II heads?
Whats the most duration that I can have on a cam when I have stage II heads (2.02/1.56) shaved 30 thousands before I run into P/V issues and I'm not wanting to fly cut the pistons - this is running the stock pistons and stroke.
Thanks
Thanks
Re: Most duration with stage II heads?
Not sure of the most you can run but I have the same setup with thinner head gaskets .050 I believe and cam is in the sig.No fly cutting is requried.
