Shopping list for building a stroker from scratch
1) bare block
2) main caps
3) main bearing
4) main bolts
5) connecting rods
6) connecting rod bearings
7) crankshaft
8) lifters - hydraulic or roller
9) main front seal
10) camshaft
11) cam bearings
12) timing chain
13) harmonic damper
14) push rods
15) heads( that can be an entire list in its self <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )
16) head bolts/studs and gaskets
I am sure I still have things to add to my list, but so far I think I am on track.
Nate
ARP sells main studs now. may want to consider them. you will want the block honed and decked. also deck the heads, port them, and may want to consider double springs. have the rotating assembly balanced (with crank pully and fly wheel as well). here is what is going into mine:
Lunati 4340 forged crank
J&E pistons (dish) 9.5:1 compression ratio
J&E rings
Manley Pro Series Light Weight connecting rods
Comp Cams 218 / 224 .527 / .534 114 LSA cam
Comp Cams adjustable timing set
Crane Cams 1.8 rocker arm kit
Comp Cams 987 valve spring
Titanium retainers
King bearings
ARE high flow oil pump
Manley Valves
LS6 intake manifold
Ported throttle body
Polished, ported, 5 angle valve job heads
Balanced rotating assembly
ARP head/main cap studs
T Rex in-line pump
Walbro 255L in-tank pump
Billet high flow rails (#10 in #6 out)
42lbs injectors
After-cooled Vortech T trim supercharger (13psi)
<small>[ July 23, 2002, 10:51 AM: Message edited by: 11 Bravo ]</small>
