Crane gold roller rockers HP???
So harland sharp is the way to go? I wanna stay stock heads for as long as possible.
http://www.vincihighperformance.com/...TRUCTIONS.HTML
I think from a general observation these are very well designed rockers, which if you look at the shape you can see why the material is put where it is. The HS rockers are basically flat and the material is not put in areas that can help strengthen the rocker. Crane seems to have added material to strengthen the rocker that will be in compression rather than tension, which is key to a long life.
231/237 .595/.598 110lsa
She's gonna be a beast.
I'm n00b.
Oh well, if the heads come off again for some reason I will re-visit the Crane shaft rockers.
I got one of the first sets of Dart heads when they came out and the Cranes wouldn't quite fit (Dart has since corrected this minor issue). So I fully disassembled the heads and used some tools to fix the issue. When I set up the heads, I tried the stock rockers and the Cranes on the workbench with checking springs to assess the wipe pattern. The stock rocker wipe pattern was not consistent and was very very wide. With the Cranes, I could get a narrow wipe pattern (for a single direction wipe as the LS1 rockers are) and had full control over the setup which I liked. Here are my Crane 1.7 fully adjustable stud mounted rockers on the Dart heads after I installed them.
Either way you choose to go, either of the Crane rockers are great products.
