Head Gaskets - Z06?? (N/A vs. Boost)
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Z00:
<strong>If you are going to stay NA the stock gaskets should work. However, for spraying, the cometic ones might be better. You have to check which heads you have though. If they are pre 2000 they won't work due to there being some differences in the heads.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually I took the nitrous off the car but I'm now thinking about forced induction.
When you say "If they are pre 2000 they won't work due to there being some differences in the heads." do you mean that if my heads (1999) are pre-2k then the cometic gaskets will not work??
<small>[ July 23, 2002, 01:40 PM: Message edited by: jhelms ]</small>
I thought I'd put this here rather than in the forced induction forum.
What is the best head gasket for a 400+rwhp n/a M6 LS1?
I've heard the 'Zo6' head gaskets are good but have not done any research on the topic - anyone know how much the head gasket kit runs?
The word on the street is the Cometic gaskets. At least thats what my research turned up. You can get just about any thickness you want.
You might want to do some research on it. There were some guys that had notches in their heads. I honestly cannot remember if it was 98 only or 98 and 99. I would probably go cometic if you are going to go FI though.
Check out this post
https://ls1tech.com/ubb/ultimatebb.p...=006160#000000
Check out this post
