Oil Pressure Question
Old Feb 22, 2007 | 03:12 PM
BLKWS.6's Avatar
Default Oil Pressure Question
When I see "XXpsi" on my guage, is that a measure before, or AFTER the filter? What I mean is, if it is measured BEFORE the filter, then a more restrictive filter will actually SHOW higher oil-pressure on the guage, if it is AFTER the filter, it will show lower pressure the more restrictive it is. I just dont know what the case is.
Old Feb 23, 2007 | 03:18 PM
BLKWS.6's Avatar
TTT
Anybody?
Old Feb 25, 2007 | 03:48 AM
BLKWS.6's Avatar
Bump...come on
Old Feb 25, 2007 | 05:12 PM
Camaro Rick's Avatar
Oil pressure is regulated by a relief pressure valve in the oil pump. There is a bypass system before the filter which shuts the filter off once pressure raises. A different filter will have no effect on your pressure readings. Your oil really only goes through the filter at idle and really low steady rpm anyway.
