Another cam question (oh-oh).. Piston to valve clearance with 226/234-XE-R
This is the cam I am looking at, for good power & to optimize the nitrous.
My stage 2 heads have had the minimal miled, just enough for cleanup. I just want to know if this cam will clear on the XE-R grind? Thanks.
I think you will be fine. The intake is what you have to worry about and if you are only cleaned up 226 intake duration should be no problem. I would call Barry just to make sure.
Cheers,
Chris
ps- the 226/234 XE-R will be awesome in your car <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ July 26, 2002, 12:01 PM: Message edited by: Chris ARE 360 ]</small>
Cheers,
Chris
Shorty Director
I agree. There are people running 226/234 with .030 milled off with no problems.. Even with the lift I would think you would be ok.. Now a 234/226 would be a different story![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
<small>[ July 26, 2002, 11:52 AM: Message edited by: VINCE ]</small>
Chris, have you ever heard of a 227/230 on a EX-R? Doesn't look like much difference, other than less exhaust.
