What is the correct way to install valvesprings?
Ditto. There's really no wrong way. To be safe, it's a good idea to get a valvespring height micrometer and make sure the installed height is correct. If you're just replacing your stock springs, you should be fine since the 918's use the same installed height as the stockers.
The root of all evil.. some pics for you
during your valve spring change..
http://www.ls1info.com/article.php?sid=157
(note link to vavletrain near bottom of above )
Pretty good article on spring swapp here..
http://www.ls1info.com/cam_install/default2.html
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TA_2001:
<strong>Pretty good article on spring swapp here..
http://www.ls1info.com/cam_install/default2.html</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Excellent write up <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
