TREX lows #'s. Not Happy....
I have a trex and am 12.5:1 and run CA 91 pump gas
I have a trex and am 12.5:1 and run CA 91 pump gasBen T.
Plus, the 38's are $20 cheaper
I'm assuming the 38s are SVO, but if not, pick up the 42#'s for the same price as the 30#'s. There won't be any problem tuning idle with those, and they'll allow you to make all the power you can possibly want NA.And seeing a T-Rex peak HP at 6200RPMs means your intake is holding you back big time. My car made 421/400 through my Magnaflow on their dyno and I have a much smaller cam than you (though I had an LS6 intake at the time). On the flip side, the 4.10 gears are taking away probably close to 8-10rwhp and I also have a U/D pulley and at least another 1/2 point compression.
EDIT: Even my peak TQ occurs at a higher RPM, which is interesting. Definitely change the intake first. Wish I'd had seen this post about a month and a half ago before I sold my LS6 intake. Would've let you bolt it on before buying it to see if it fixed your problem :doh:
Get your self a ported Fast with accompaning tb/injectors and get the car retuned....it will be a comletely different animal!
Good luck!
Milling the heads isnt going to really gain you any peak numbers but it will help out down low.
Do yourself a favor and replace your intake before you do anything else.
Then dont get caught up in the over blown theory of having to have the perfect dcr to make power.
Only problem with this guys setup is the intake but you've got people here telling him to pull the heads. WTF?!?!?
You could check the compression real quick to rule and it wouldnt be a bad idea. You dont need a leak down test just buy a guage and foillow the instructions. If there is an issue you'll see it. I was having an issue with being down on power and simple conmprssion check chowed me I had 180 psi in all cynlinders exxcept for one wich had 60psi.
Regardless of what you find with the compression check you still need at least an ls6 intake with a cam of any size.
Also new injectors?!? where on the a/f graph do you see him going lean on his dyno run? stock injectors are good to about 450 rwhp
This guys problem is the intake
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
well that's no good.
