P/V clearance
Old Jul 27, 2002 | 04:10 PM
BYBYC5's Avatar
*Bad Trader*
Default P/V clearance
with 222/222 .595.595 111 and 5.7L heads i want 11.0-1 C/R what do i need to do, what valves to get and what are the biggest valves i can put into my heads without machining to fit. how much to mill and will i have p/c problems....
Old Jul 28, 2002 | 10:45 AM
BYBYC5's Avatar
*Bad Trader*
Default Re: P/V clearance
ttt plz
Old Jul 28, 2002 | 03:43 PM
DriveATransAm's Avatar
you can mill .040 to get about 11.1:1. im not sure about the valves though.
Old Jul 29, 2002 | 12:03 AM
RedlineSS2000's Avatar
hey grinch whats up you make it home all right. WE did. But anyways just incase you forgot 2.055 on the intake side and 1.60 on the exhaust side. I wouldnt mill the heads over .30 but with .30 you will get around 10:8:1 compression. Give me a call on my cell i am off this monday and we can talk about it on the phone. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Jul 29, 2002 | 02:45 AM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Grinch:
<strong>with 222/222 .595.595 111 and 5.7L heads i want 11.0-1 C/R what do i need to do, what valves to get and what are the biggest valves i can put into my heads without machining to fit. how much to mill and will i have p/c problems....</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">2.02 on the intake and 1.56 on the exhaust.My heads are milled 30thous and you should be fine with that cam.Raughammer has his milled 60thous and runs a 224/224 581/581 112 bumpstick with no piston to valve issues.
Old Jul 29, 2002 | 07:44 AM
Fireball's Avatar
you should be fine...
I have .040 milled off of 5.3L heads with 2.02 valves and a 232/232 camshaft. I only had to notch .020 for that which is hardly nothing. a 230/230 probably wouldn't have needed anything <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
