12.2 CR on 91 octane
Old Feb 23, 2007 | 03:14 PM
lazylongboarder's Avatar
Default 12.2 CR on 91 octane
I'm thinking of upgrading my bottom end and was looking at a set of mahle pistons with a dome volume of -4 cc's and ='s 12.2 C/R with a 64 cc head. Will this thing run to lean with 91 octane? If so, what's the max Compression i can run with pump 91? Thanks guys.
Old Feb 23, 2007 | 03:48 PM
5.3LJimmy's Avatar
My calculator says 11.28:1 Compression ratio. Stock bore ls1, 64CC Head, Stock .052 head gasket, w/ -4cc piston. You can probably run that w/ 91 octane, but you may have to back some timing out to prevent knock.
Old Feb 23, 2007 | 05:51 PM
SUTTERERMAN85's Avatar
what is your dynamic CR you are going to have?
Old Feb 23, 2007 | 08:15 PM
hammertime's Avatar
Exactly, 12.2 might be ok if you are running a really healthy cam. But if you're not in the high 230's or better, thats probably too much.
Old Feb 24, 2007 | 01:18 AM
DONAIMIAN's Avatar
You had to of entered a number wrong in your calculations. With thoes pistons it will be around 11.2 like said above.
