To stroke or not to stroke?
Old Feb 27, 2007 | 01:18 PM
TransAm8723's Avatar
Looks like a good project, good luck. Seems like you are shooting a little higher than me, especially with a potential 300 shot and all... lol I was only considering a 200 shot at the most.
Old Feb 27, 2007 | 03:25 PM
david vericker's Avatar
Originally Posted by orangeapeel
I think that you can just get the 382 rotating assembly and have it balanced and installed without really even touching the block.
I would get a cam spec'd out and custom ground before I went with an off the shelf grind on an all out but streetable car.
You must hone the block for the after market forged pistons.
Old Feb 27, 2007 | 09:44 PM
zo6vetteman2003's Avatar
I agree. The cylinder bores will need to be enlarged only .0005" from the honing. They will use a deck plate when this is done to simulate the heads being installed. This will cause the cylinders to be more concentric, resulting in better seal for the rings and better oil control. Find a good shop with an operator that knows these blocks.
