Help me pick which heads/cam to get.
#82
Re: Help me pick which heads/cam to get.
JS your car is going to fly with that setup <img src="gr_stretch.gif" border="0">
I am planning a similar setup but with Hookers
(1 3/4 headers, 3 inch int pipe 3.5 inch collector, 3.5 inch cutout back into 3 inch overaxle and bullet)
I am hoping to line up an all bore 382 with a 226/234 cam on at 112LSA and 590 lift with dual springs and 11.2:1 comp too. That is my dream <img src="gr_stretch.gif" border="0">
With the 4.11's, spool and 4400 converter mid high tens should be cake <img src="gr_grin.gif" border="0">
Chris
Chris
#83
[quote]Originally posted by Pro Stock John:
<strong>Saw yours at E-Town Erin...
</strong><hr></blockquote>
You saw me at Etown and didn't say hello? Shame on you <img src="gr_tounge.gif" border="0">
#84
[quote]Originally posted by Mark IXZD 150:
<strong>Can we revive this? How about making it a 100 post thread?
I see a lot of people asking the same questions.</strong><hr></blockquote>
Ok Mark I'll help, have you made the final choise, is it the 224/112lsa?
#87
[quote]Originally posted by Top Fuel:
<strong>nice car. <img src="gr_stretch.gif" border="0">
is that the 36.5mm or 50mm offset on those rear wheels?</strong><hr></blockquote>
50mm
50mm
#88
[quote]Originally posted by smokin' joe 00 ss:
<strong>
Ok Mark I'll help, have you made the final choise, is it the 224/112lsa?</strong><hr></blockquote>
I still can't decide. I wish I could go hear someone's car locally before I make my final decision. If someone could answer my previous question comparing the two lsa's, I might be closer to a decision. I'm torn. I also can't decide whether to go 222 or 224. Maybe the Hammer cam.... AAAAARRRRRRGGH! <img src="gr_eek2.gif" border="0">
Somebody decide for me!!
<strong>
#89
LS1TECH Sponsor
[quote]Originally posted by JS:
<strong>
I'm going to something on the lines of:
226-234 591-591 113LSA very soon w/Cartek S2 LS6 Heads,Ported LS6 Intake,11.2CR,Dynatech Stepped LT w/3in Y into a 3.5interm. to a 3.5in Cutout an then back to 3in over the axle and to a round race magnum single out,TP4600,4.10's w/ALL the sups. goodies
Should make for an interesting setup
JS</strong><hr></blockquote>
JS: Can you do that without fly cutting the pistons? Interesting coice of cam duration...hehe, that's exactly the duration that I used to run.
[ January 13, 2002: Message edited by: mikey ]</p>
<strong>
#90
Those street tires won't grab at all with 420rwhp...IF you punch it you will be all over the place... <img src="gr_stretch.gif" border="0">
#91
<strong>
Somebody decide for me!!</strong><hr></blockquote>
I know what your going through it's a tuff decision 222, 224, B1, T1 or the <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" /> (Hammer)are all very close but I think the final decision is really with driveability and not how tough it sounds, I've had plenty of cams that thump in my big blocks but these cars are really about being all around street cars. So I'm really leaning towards the <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" /> (Hammer) for those reasons and after I heard a sound clip over on LS1info.com but it didn't say which LSA it was.
<strong>
#92
LS1TECH Sponsor
[quote]Originally posted by jmX:
<strong>As for the heads, you probably cant go wrong with whoever you go with, but ARE has issues with lead times and attention to detail. They just seem too busy right now with work.</strong><hr></blockquote>
jmx: Please explain yourself. ARE is 3-4 weeks ARO for stage II heads. We just had a customer cancel his GTP order and ordered from us because GTP was backed up according to him, 3 months.
Attention to detail? Where did you ever pull this one from?
Mikey
Mikey
#93
1 Post
BIGBOS is right if you're makin' 420 rwhp, you'll be all over the place - unless you back pedal it out the hole and don't get into to it till the top of 2nd on street tires. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
BTW, I'm the guy making 429 rwhp with the C1 cam on Campbell's dyno graph - in the earlier posts.
#94
Leo you are on street tires right and a 3.42 gear??
As soon as you nailed it we could hear you breaking loose...imagine if you had a 4.10 gear <img src="gr_eek2.gif" border="0">
#95
I'll throw my .02 in here.
I was kind of money conscience when I looked at my combo. What I found was that it makes just as much if not more hp than the high dollar stuff. It idles like a dream compared to many of those other lopey cams or even the LS1 hotcam.
I have the B1 spec Lunati cam and Stage 2 heads which are fitted with 2.02/1.60 ferrea valves, Isky springs, and titanium retainers all for less than $2400 including the pushrods. I will post the graph tonight. The numbers were 431rwhp and 405rwtq. 1/4 mile times in the sig. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
[ January 13, 2002: Message edited by: Smoke_ur_5.0 ]</p>
#96
Location: Oklahoma 1000+ posts from LS1.COM and 430+ posts from WWW.COFBA.COM
What would be the average cost of heads and cam plus installation??? Thanks!
#98
LS1TECH Sponsor
<strong>No Mikey u can run that w/o cuttingthe pistons
No biggie as Julios has the tool to do it in the car.
I still don't understand. With a 2.055 valve, according to my math, you can only safely run a 0.560 cam on the intake side. With a 2.02 valve it's just a litte larger @ 0.570. 11.2 CR is going to require a good cut off the head surface, like 0.045. No way you can run that much lift without a fly cut. Correct me if I am wrong.
#99
D(irecto)r Pepper
Smokin joe, that was mopst prob a 112 l/s you heard on the sound file. VERY few hammer cams out there on 114 l/s. I have two buds fixing to go to the hammer on a 114 but i have seen no sound files of them on the net.
Mikey. .560 is no where near the limit on lift before you run into valve/piston probs.
.590+ lifts have been run. It is a combo of lift, duration that will cause problems.
MANY folks have run 2.055 valves and .566 lift cams with ZERO valve/piston problems.
( I am very tired (massive O.T. at work) and hope my reply does not sound too "crabby" )
J Campbell
p.s., To the guys who have sent me email tech questions, i will be replying to them tonight at work, sorry for the wait)
J Campbell
#100
My B1 sounds pretty mean to me, but then again i'm running mac headers & o/r pipe and cutout. When capped it's going through a flowmaster anyway, so as stated it still is noticable. Nobody mistakes my car for stock. I will admit though some days i wish i had a stock dual/dual on there again, cause this loud business gets old sometimes!
