Timing Chain Install (Haynes Manual)
Old Jul 30, 2002 | 01:48 PM
WhynotSS's Avatar
Default Timing Chain Install (Haynes Manual)
The Haynes Manual says, "Timing chains must be replaced as a set with the camshaft and crackshaft sprockets. Never put a new chain on old sprockets."
It seems like a high percentage of us are replacing only the chain when doing a cam swap. Why can't you put a new chain on old sprockets? Is their advice for damaged chains only?
<small>[ July 30, 2002, 01:53 PM: Message edited by: WhynotSS ]</small>
Old Jul 30, 2002 | 01:52 PM
StevieZ's Avatar
Default Re: Timing Chain Install (Haynes Manual)
As long as the teeth on the spocket are good and show no wear, you will be OK.
Old Jul 30, 2002 | 05:36 PM
NastySSoo's Avatar
IMO the chain is a pain in the *** to change. If I was in their id certainly do the sprockets also! My 02!
Old Jul 31, 2002 | 12:34 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Well how much would the sprockets cost?
