Engine losing power/ surging at 5400 RPMs
<small>[ July 30, 2002, 10:14 PM: Message edited by: XSuROsISX ]</small>
<strong>egr o ring leaking??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This could also be the problem, When my car was acting like this I looked alot into the problem and the EGR ring, Pulley, and plugs and wires were the most likely culprits.
If you can get the car on an ATAP that would be a lot of help, if it is the pulley check for knock retard and random misfire codes on different cylinders above 5400 (what mine was doing)
*Edit* - If all of the above seem to not be the problem check your pushrods to see if they are all straight.
<small>[ August 01, 2002, 08:17 PM: Message edited by: Bad Habit Bird ]</small>
