Car troubles again....HELP!
Any more ideas?
It knocks pretty bad for have only sprayed a 75 shot of fuel at it... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
https://ls1tech.com/ubb/ultimatebb.p...;f=23;t=001884
I also saw this tidbit of info on http://www.automotiveforums.com/vbulletin/t476.html
Specifically:
"Also new on the 2001 models is the reluctor wheel which is attached to the crank to trigger the crankshaft position
sensor which is now redesigned to enhance signal output."
Is it possible a 98 PCM Flash is not compatable with a 2001 with respect to a CPS signal? I guess this would have been identified with others if it was an issue, but like I said I don't know much about cars and just thought I would throw that out there.
Regards,
I'm off wed. so call me and I might be able to check it out.
<small>[ July 31, 2002, 01:38 AM: Message edited by: JimTA ]</small>
I might take an MPG tonight if Bill gets home soon.....and then upload it here...
TTT...
just cause it doesnt have misfires doesnt mean anything. the misfire codes could have been taken off to make the programming look better for the $
