T&D shaft mounted rocker arms?
Do I need machining to make these work on my ...urrr I mean my buddys car and also what kind of pushrods will he need.Oh and will these work with any dual spring setup besides comps?If there are any other rocker arms out there I am open to suggestions.
For T&D's install,you need to clearence a bolt boss on the inside of each head,elongate the pushrod hole and setup proper rocker arm geometry using shims under the mounting bar.You also need to swap to a shorter pushrod,generally 7.250"-7.300"
The rockers will fit any spring\retainer combo in 1.46" dia and 1.55" springs if they are clearenced,and they will work on either hyd or solid cams.
Thanks everyone now where do I get the jesels and do these require any maching or no?Futral what do you recommend?Shoot me some prices and a list of what I need.Thanks again everyone.
