Help with LS6 heads and cam selection
Old Aug 1, 2002 | 09:14 AM
Badazzvette's Avatar
Default Help with LS6 heads and cam selection
I've got a stock set of '01 LS6 heads going on my '98 LS1 'vette and want to cam it. What would be the highest lift I should use using stock LS6 heads. I don't really want to put springs in the heads. How about duration and LSA? What would be the most aggressive cam you guys would use with this setup? What kind of numbers can I put down at the back wheels with only CAT backs? Also, I want a good idle and don't intend to do any tuning, at least not initially. I want a good daily driver and reliable car but want some good power with the emphasis being on a daily driver that is reliable.
Does anyone know the specs on '01 LS6 heads? Valve sizes, flow rates and how good are the springs?
<img border="0" alt="[Corvette]" title="" src="graemlins/corvette.gif" />
Old Aug 1, 2002 | 06:02 PM
VINCE's Avatar
Shorty Director
Default Re: Help with LS6 heads and cam selection
I would go with with the GM CNC ls6 heads. The flow #'s would be perfect for the ASA cam..
Old Aug 2, 2002 | 12:04 AM
AlonzoVersion 1.0's Avatar
No matter what you choose any after market cam is going to need new springs and possibly retainers.It just depends on what you choose.
Old Aug 2, 2002 | 12:51 AM
Z00's Avatar
Z00
If they have the ls6 springs you could go with something similar to the 01 ls6 cam. Wouldn't want to go about .525 lift
