Stock LS1 Heads valve replacement
I will be receiving a pair of LS1 heads to work for a friend of mine and Ive heard the the seats are extremely small. Will a 2.02 in and 1.60 ex fit on the stock seats or will they need to be replaced with larger seats ? and Ive noticed that they have cone topped valve springs with small diameter retainers, are these there to clear the stock rocker arms or can a std 1.25 springs and retainers be used with out interference ? Thanks for your help guys.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Dunno if the seats can be milled up to accept the bigger valves, but stock spring width is approx 1.25.
The stock springs are "beehive" style. I don't know the reason why beehive (conical) instead of cylindrical. As long as the "standard" springs yer planning on using can handle the lift & ramp rates (may need to shim) they should be okay. Comp's -941's are cylindrical and lotsa fellers have used them...
I have 2.02 and 1.575 valves and stock seats--no issues.
I think 2.05 intake and above require replacements...
you should still check on the 1.60 exhaust, though--dunno on that one...
