110 LSA on highway ?
Old Feb 25, 2007 | 09:58 PM
35thUCF's Avatar
Default 110 LSA on highway ?
Does anyone have any warnings about running the ASA cam on the highway, will it surge and buck around (like many have told me) ?
Old Feb 25, 2007 | 10:02 PM
cowboysfan's Avatar
if tune is good and running gears say 3.90 or higher. should be ok. w/ those gears I'd say needs tuning. .02
fuerzaws6
Old Feb 25, 2007 | 11:12 PM
2000RedZ's Avatar
It will be fine if tuned properly, I drove mine around alot when I had it with stock 2.73s
Old Feb 25, 2007 | 11:13 PM
BorgerTransAm's Avatar
+1 for the tune
Old Feb 26, 2007 | 03:26 AM
PREDATOR-Z's Avatar
Won't be an issue on the highway but more in stop and go traffic.
Expert tuner would take care of that. Max gears I would go is 3.73:1
Old Feb 26, 2007 | 09:01 AM
35thUCF's Avatar
I am keeping 3.23, thanks for the help guys
Old Feb 26, 2007 | 09:03 AM
Justin00SS's Avatar
Is this only a problem with auto cars?
Old Feb 26, 2007 | 10:13 AM
YellowToy/A's Avatar
What are the rest of the cam specs???? bigger cam have more problems than smaller. LSA is just part of it.
Old Feb 26, 2007 | 12:06 PM
35thUCF's Avatar
ASA cam:
226/236 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
110 LSA
Old Feb 26, 2007 | 02:26 PM
Not much lift. Why the big duration on the exasht? I would cut the exh and go with a smaller LSA.
Old Feb 26, 2007 | 04:54 PM
ProjectCamaro's Avatar
The GMPP's ASA cam is known for having a good tq curve and a nice choppy idle. I would personally say set up the gears to at least some 3.42's which you can get really cheap used since they are the stock gears for the M6 cars.
Old Feb 26, 2007 | 06:13 PM
JBIRD02's Avatar
With this cam and stock 3.42's, I can cruise as low as 55mph in 6th gear with absolutely no problems. I only experience a little bit of cam surge if i try to cruise @ 1500rpms in 3rd or 4th gear, and even then its not bad at all.
Old Feb 26, 2007 | 06:30 PM
GuitsBoy's Avatar
More well rounded cams out there... Any reason youre sticking with this one in particular?
Old Feb 26, 2007 | 08:52 PM
Cop Car's Avatar
imo G5x4....
my x3 on 110 dosent buck around on the highway.. only time it really does is when you are going down hills or sometimes when you let off the gas when its locked up. its not a big deal at all and you wont notice it.
Old Feb 26, 2007 | 10:43 PM
GR33N GoblinM6's Avatar
would it be a better cam if it was on lets say 112?? i was thinking about the ASA cam for quite a while.. but the 110LSA im not liking...
was also thinking about going custom and doing it on 112... any thoughts?
Old Feb 27, 2007 | 05:59 AM
97Rob's Avatar
My 110 is very streetable. It was spec by Bret Bauer. Had a 112 that bucked and surged. A lot seems to be in the tune.
Old Feb 27, 2007 | 08:19 AM
jub jub's Avatar
I think the attractiveness of this cam has to do with the lazy lobes. Other than that, I can't see why anyone would want to run one.
Old Feb 27, 2007 | 09:23 AM
bww3588's Avatar
who did your tuning for you?
NVM....got it off your dyno page.
Old Feb 28, 2007 | 09:31 AM
JBIRD02's Avatar
Actually, the attractiveness of this cam (to me at least) is the flat torque curve it has (check my dyno graph). Also I like the fact that I made good #'s without having to turn high rpm's. As an added benefit, I can run LS6 springs which are cheaper and wont have to be changed as often, and I have a killer lope!
Old Feb 28, 2007 | 09:43 AM
jub jub's Avatar
That cam does have a nice torque curve I will admit.
I wonder what kind of numbers I would get with my AFR heads?
