Need Comp Spring Tech Data Please...
Old Aug 4, 2002 | 10:14 PM
2xLS1's Avatar
Default Need Comp Spring Tech Data Please...
I need the remommended installed height and coil bind height for both the 918 and 941 springs. Also, the spring pressures at the installed height and at max lift Thanks.
Old Aug 4, 2002 | 10:20 PM
Onyx LS1's Avatar
Default Re: Need Comp Spring Tech Data Please...
Installed Load: 105 lbs @ 1.800" 130 lbs @ 1.800"
Open Load: 293 lbs @ 1.200" 318 lbs @ 1.200"
Spring Rate: 313 lbs/in 313 lbs/in
Coil Bind Height: 1.085" 1.085"
Outside Diameter: 1.290"/1.060” 1.290"/1.060”
Inside Diameter: .885"/.656” .885"/.656”
Retainer: TI 772/Steel 774 TI 772/Steel 774
Part # 26915-16 26918-16
Description GM LS1 Spring High Load Spring
Old Aug 4, 2002 | 10:26 PM
2xLS1's Avatar
Great info. Thank you. Now if I could get the same data on the 941.
Old Aug 4, 2002 | 10:27 PM
Onyx LS1's Avatar
I think the 941 was discontinued when they came out with the 918 so that info isn't on their website anymore, I'm sure you can find it somewhere though.
