which to buy GTP stage 2 or MTI stage 2 heads?
SSU Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
but what did john run in a similar DA with his stripped car. well, not stripped...but 3300lbs isnt actually full weight..especially since some of that weight is a cage. also, didnt john run 10.66 like one time? he run's 11's in the current DA, right?
CMarsh went 10.94 (first 10-sec h/c car i believe) with a GTP heads/cam. 3450+lbs...a while ago too.
hell, Jantzers home ported heads and OLD mms 224 cam go tens.
I still like GTP for the simple reason that GTP cars have nearly equalled any feat an MTI car had done...and they're a little less moola.
but dont get me wrong....MTI kicks ***. john's car is 'ok' <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Texas Director
I'll let John chime in if he wants to post any of his times. I'm not going cough up that information. He is the only to share his times. I don't think he will though since we are street racing right now.
LS1Tech Co-Founder
Terry, don't kid yourself about Raughammer being completely gutted like you think. Your car is at least as gutted and weight-reduced as his is. His isn't to the level of Colonel's car, not even close. John still has A/C and all the belt-driven accessories, not to mention the stock brakes. His new lightweight hood and battery were not on the car in the fall, they are recent.
And, his car is always evolving. You have a moving target on your hands.
Ryan, GTP heads are cheaper because there is less labor involved. GTP stage 2s use stock valve seats, MTI stage 2s have hardened, larger diameter valve seats and bigger valves.
Some people argue for the valve size, others argue against it. All I know is that MTI seems to be the most consistent based on all of their customers that post on the net.
Tony
Tony
SSU Moderator
Tony, you're right. we need a light A4 guy with MTI's stage one heads to make a good comparision (apple to apple). But since the thread was S2 vs. S2... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
If I was doing it for real...and I didnt get a hook-up from Speed Demon or TR...I'd get MTI Stage One heads and that fancy X1 cam. I'd just call it a COMP CAM, lol.
Terry,
One thing you may want to do is do a compression check. You have been running the blower with issues for a while and might have a cracked ringland. Might influence your decision. I dont know if GTP sells complete bottom ends, big bores etc like ARE/MTI do but that might affect your decision. (You would want to go from the same source for a complete motor for warranty, ease of install and just peace of mind. Both companies do great heads but you may need more than that.
Best of luck,
Chris
Best of luck,
Chris
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I've got a solid roller cam and 13:1 LS6 heads in the works right now, so if he's a moving mark I'm a guided missle. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
He never posts pictures of his car so it's hard to tell what he really has, but from when I've read of people who have seen it, he is missing all his interior, and has spent a lot of time gutting the car. What is his raceweight? I know they have scales at HRP.
I just need to figure out how to get that 1.38 60' time and I'll be able to pass him up. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
chris,
I kinda think the ati just needs tuning and injectors to run properly, so far 11.91 was my best in the HEAT. A compression test is a great idea though which I might look into. I am anxious to sell the charger and see what I run then without it.
HERE IS WHAT I AM DOING FOR SURE:
what should this run? mid 10's?
mti stage 2 ls1 heads
mti X1 114 cam
ls6 intake
tnt 100 wet shot
yank tp 4400
sending my computer to MTI.
I already have my suspension dialed in and pulling the wheels!
mti X1 114 cam
ls6 intake
tnt 100 wet shot
yank tp 4400
10's in my future?
my charger>>> http://cgi.ebay.com/ebaymotors/ws/eB...ndexURL=0&rd=1
yes, after thinking about it I am going to run my vig 3200 a bit then do the pro yank 3600 extreme
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong>x1 cam on a 114 should spin some high rpms. 100 shot will be ok. for 150 shot I wouldn't go above 4000 stall.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ragtop 99 you are saying that the car will respond well to a 100 shot so long as its not over a 4000 stall?I have heard you will only gain 4-5 tenths but that was with a 4400 stall as well.Looks like I maybe strapping on the bottle as well.
#32
SSU Moderator
i wouldnt use a loose 9" 4000 stall...that could be too much. more like Yank's 6-bolt 4000 stall....or a vig3200 stall (3800rpm). the vig will flash to 4500 or so...maybe more.
#33
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nine Ball:
<strong>Terry, don't kid yourself about Raughammer being completely gutted like you think. John still has A/C and all the belt-driven accessories, not to mention the stock brakes. His new lightweight hood and battery were not on the car in the fall, they are recent.
Tony</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The first Dyna Batt I ever saw was on Raugh's car OVER a year ago...
Also, in the pics I just saw he did not have power steering (just like me)...
#34
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Terry Burger:
I just need to figure out how to get that 1.38 60' time and I'll be able to pass him up. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> [/QB][/QUOTE]
1.)OH man 13:1 sounds Real streetable! Your heat seeking missle will be a trailer queen just like a real missle (not to say it already isnt <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> )
2.)Raugh DOES post pics of his car. He just posted like 5 of them with his new hood. Look on his web page. And, in all the posts I've seen of his he DOES post raceweight.
3.)And Terry, you need to figure out how to get your racecar out of the mid 1.5's before you consider 1.4's let alone 1.38's LOL!
#35
I can shift faster than you.
I have had great luck with the GTP stage 2s on my car last year. The car went 11.16@125.59 with a 3450 raceweight. The car was just a 60' away from a 10.90 pass with a N/A stock-bottom end car.
You really can't go wrong with either set of heads. Good luck with your setup.
Jason
<small>[ August 06, 2002, 08:49 PM: Message edited by: Jason99T/A ]</small>
Jason
#36
thanks for all the replies guys!
as soon as my charger sells on ebay I will be calling up mti!!!
I am wondering if it's worth trying to find a set of ls6 heads used to have them port? good for another 15hp?
#37
D(irecto)r Pepper
Freaking Hillarious Thread! <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">He never posts pictures of his car so it's hard to tell what he really has, but from when I've read of people who have seen it, he is missing all his interior, and has spent a lot of time gutting the car. What is his raceweight? I know they have scales at HRP. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry, that whole paragraph is so off base, I would'nt know where to begin to respond. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Terry (the topic starter), While both GTP and MTI have some good heads. I would have to give my vote to MTI. I could not be any happier with the streetability and power of my set up as it sits right now. It is just so tame and dependable..... but lordy when the hammer goes down, does it puts down the numbers!
Do your research, study the choices and make a good decision. Good luck on whatever you decide to do. If I can help you out with any pertinant info, just drop me an e-mail.
Later fellas.
p.s.:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Raugh DOES post pics of his car. He just posted like 5 of them with his new hood. Look on his web page. And, in all the posts I've seen of his he DOES post raceweight.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">DITTO!
Later fellas.
p.s.:
#38
1.)OH man 13:1 sounds Real streetable! Your heat seeking missle will be a trailer queen just like a real missle (not to say it already isnt )
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It will work great on the street, it's all in the tuning (IE having two timing maps).
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So what is his raceweight on the 10.66 runs?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Tell me about it! I make more power than Pepper and run the same stall/gears. If I had some traction I bet I could get in the low 1.40s. I spun to my best 60' of 1.50 (thus far).
#40
I'm very happy with my GTP S2 setup <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Times in the sig.. with 3.42 gears....
Hope to have new dyno numbers this weekend <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
