View Poll Results: What lifters should I use?
Comp 850-16's
22
14.86%
LS7 lifters
74
50.00%
Cadillac Racing
52
35.14%
Voters: 148. You may not vote on this poll
Lifter poll!!
Old Mar 23, 2007 | 09:14 AM
  #41
2c5s's Avatar
Originally Posted by AMERICAN_HP
How many people have actually "Used" the caddy lifters??
It seams that every time a new product comes out everyone starts to make unfounded reccomendations about using it??
How many people have actually had a failure with the LS7 lifters? How many people "Know" that the caddy lifter will be more benificial to use?? (on a street car that will NEVER see 7000+ rpms.)
Just because its twice the cost doesnt make it twice as good..
I vote for the tried and true LS7 lifter.. Cause I would be willing to bet the cost of the lifters that you will NEVER see 1 ounce of advantage or reliability increase by going with the caddy lifters.
Is'nt your engine in pieces because of a noisy lifter?
Old Mar 28, 2007 | 08:56 AM
  #42
CaMaRo67RS355's Avatar
i just got the comp o.e.'s but i was thinking about the caddy's... is there much different between them?
Old Mar 28, 2007 | 06:48 PM
  #43
SS1875's Avatar
I am running the Comp 850's on a .631 lift cam and they are going strong bought them used for $80...they make a little more noise than the stockers but bad.
Old Apr 14, 2007 | 03:51 PM
  #44
nmp27's Avatar
Caddy here, daily driver
Old Apr 14, 2007 | 03:57 PM
  #45
davered00ss's Avatar
Moderator
I bought the LS7 lifters from SDPC for under $100.
Old Apr 14, 2007 | 10:12 PM
  #46
MyTA99's Avatar
Originally Posted by Ryan02SS
Nope. I've not yet personally seen a LS7 or Cadillac lifter but I have compared the Comp's to a set of Morels. It was simply a Model A compared to a Enzo. The Morel's were top notch. Roller wheel was much higher polished than the Comp lifter, thickness of the Morel body was amazing compared to the thin body of the Comp, heat treating process was far superior.
From what I have personally seen, the Morels are the best out there.
Well that didn't answer the question.
Old Apr 14, 2007 | 10:42 PM
  #47
mochiles's Avatar
Crane 10530 lifters here.
Old Apr 22, 2007 | 12:04 AM
  #48
DarkDemon's Avatar
do u have a link to that site?
Old Apr 22, 2007 | 07:27 AM
  #49
RGKSR's Avatar
Default Here's the SDPC link
http://www.sdparts.com/product/12499...esSetof16.aspx
I sent you a pm, I've got a new set of LS7 lifters I'd sell for $90.00 shipped.
Bob K.
Old Apr 22, 2007 | 02:31 PM
  #50
Tom@SpeedInc's Avatar
Run a set of Comp 850 lifters myself, no complaints.
I'll try Morels at some point
Old Apr 22, 2007 | 07:30 PM
  #51
jow02327's Avatar
Originally Posted by Mike94ZLT1
Putting together a new engine, gonna have a MS4 cam and some PRC LS6 heads. What lifters should I go with? Comp Cam's 850-16's? LS7 lifters? Those Cadillac racing lifters I keep hearing about?
dont do the comp lifters. less than 500 miles on mine with the MS4 and already colapsed one
Old May 2, 2007 | 08:48 AM
  #52
01Z0H6's Avatar
i am running th LS7's...
Old May 6, 2007 | 11:59 AM
  #53
z-ya's Avatar
Morels in mine with 3/8 trend pushrods , no valve control issues to 7200 rpm.
Old May 22, 2007 | 11:25 PM
  #54
01 BERGER CAMARO SS's Avatar
I installed comps but next time around they will be LS7's
Old May 23, 2007 | 07:13 AM
  #55
BOWTIE's Avatar
After a huge wait, I will be going with the Caddy's.
Old Jun 15, 2007 | 08:16 AM
  #56
BerryWS6's Avatar
I just did a head swap and I replaced the lifters with Comp "R" lifters
has a little more vavletrain noise but not bad.
Old Jun 15, 2007 | 10:14 PM
  #57
BlkHwk's Avatar
Originally Posted by mr2guru
Morel/Lunati
Exactly!!!
DD put whatever pos stock (comp or whatever ) lifter you wanna put in. The valve train is one of the most abused area's of your engine if you plan on runnin your engine over 6k put some good stuff in there. It's a crap shoot otherwise. If your lucky go for it.
Old Dec 1, 2007 | 07:21 PM
  #58
Mike94ZLT1's Avatar
Holy old thread.... I went with the LS7 lifters in a completely different combo. They have about 6K miles on them, and have seen seven grand several times without an issue.
Old Mar 18, 2008 | 12:16 AM
  #59
98RedBird's Avatar
I vote LS7's
Old Mar 18, 2008 | 12:26 AM
  #60
Captain InsaneO's Avatar
I've been using the Comp 850-15's with zero issues.
