Stock lifter + high lift cam - opinions?
I just put in the F1 cam from FAStech - similar to MTI's X1 cam.
.591/.569 lift - what are the thoughts and/or opinions on the stock lifters here?
even if this cam has radical ramp rates, the stock rollers will be just fine. stock Gen III lifters are far from the weak point of the valve train. spend your dough somewhere else, like, timing chain.
LS1Tech Administrator
Received 1,686 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
What other option is there (except solid)? Didn’t Comp cut production of the “R” lifter?
