what are the 383 strokers dynoing now?
With cheaper "relatively" stroker cranks out now you can get into a stroker at a reasonably price and not have to worry about sleeves dropping etc and could run a big shot if you wanted.
Also you could stick with 2.02 and 1.57 valves and adjust the intake/exhaust cc's as well. (Keep costs down)
I would think 460/460 RWHP and RWTQ could be easily attainable on 11:1 comp and pump gas.
Plus you could run a bigger cam too <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I was thinking a 236/244 .600/.600 112LSA would idle pretty good in a M6 with tuning and 1000rpm idle. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
What are your thoughts? I know the all-bores have the potential for more power but for reliability I think a stroker 383 would work great and handle spray well too.
Also you could run a 3.905bore X 4.125 stroke and hit 395 cubic inches no problem.
Cheers,
Chris
<small>[ August 08, 2002, 11:04 AM: Message edited by: Chris ARE 360 ]</small>
<img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<strong>I agree but the problem is you can only run so much intake duration before PtoV is an issue. If you can stuff the biggest duration cam that can fit on the intake side, running more duration on the exhaust wont hurt at all and will help on spray/blower cars too. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Plus more exhaust duration also helps pull in a greater intake charge and helps extend HP past power peak.
Cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">PtoV is not an issue on a built motor with forged pistons, valve reliefs can take care of that. I disagree completely on the "more exhaust duration is good" theory. While its true that hanging open the exhuast valve for a bit while the intake valve begins to open does pull some more air into the cylinder, too much duration will start to bleed off that pressure. Not to mention the greater your exhaust duration, the more overlap you will have resulting in a shittier idle. LS1s dont need help in the exhaust department, and nitrous is not a consideration unless you are spraying more than a 250 shot. As far as extending the power past the peak, look at this comparison between the 230/224 and the 224/230: http://64.208.21.183/Jim/Pics/g5f1beforeafter.jpg
I find at least with my heads the exhaust biased cam works the best, but I Am not opposed to trying something new heheheh
Chris
Chris: What exactly is ARE doing differently with their heads that makes them prefer a standard split?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's me. In the last 7 months we've tweaked it from a measly 404 rwhp to where it is now. We are going to fool with the intake parts some more, like trying a Ported TB instead of the BBK and a regular lid instead of the Volant. I also just installed an LS6 intake instead of the H/L intake and need to re-dyno. I'm running 10.8 C/R, and am prett happy with my current power.
Check sig for complete list of mods
<strong>This is a little off the subject but how come HPS's Stage 2 heads are so cheap? They are only 1295.00 And thats with a 500 core charge.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I noticed that yesterday, but if you "click" on it, price changes to reflect 1250.00 after core. Also seems like they consider the addition of upgraded springs and retainers S2 over the ported only S1. How well do they perform, flow numbers anyone?
Cheers,
Chris
<small>[ August 08, 2002, 12:16 PM: Message edited by: Chris ARE 360 ]</small>
Did some tuning on a local guys 382 and it pulls 448rwhp and 439rwtq. It has a pretty small cam spec of 224/224 .539/.539 114lsa. We are going to throw in a custom reverse split in it and see what happens. Oh yeah the heads were ported two years ago so I think we may be seeing some 383s soon with all the latest head designs making 460-475rwhp soon.
I'm also curious about the all bore 382 guys too. what are the most recent numbers coming from them?
However, I am more of a fan of 4.000 bore or MORE motors. I think the secret to the LS1/LS6 are the heads, and that with a bigger bore and the right cam a 4.000-4.100 bore with LS6 heads will build more power. I think the stock 3.900 bore does well but the smaller bore is offset by the longer stroke that the LS1 has from the factory.
I like the TQ from a stroker
And no liners dropping...
JS
<small>[ August 08, 2002, 03:35 PM: Message edited by: JS ]</small>
