Question about N2O pistons and CR
Old Aug 8, 2002 | 08:45 PM
akw408's Avatar
Default Question about N2O pistons and CR
Ok, this may be a really vague question, but I have Ross nitrous pistons and heads that were milled for 10.8 CR with stock pistons and GM head gaskets. What would my compression ratio possibly be? What shape is the top of the piston?
And what makes a nitrous piston a nitrous piston? What if I were to put a blower on? Would a nitrous piston still be good to go? Thanks!
Old Aug 9, 2002 | 08:32 AM
Big Mike's Avatar
Default Re: Question about N2O pistons and CR
I can tell you this: Nitrous pistons are designed to have lower ringlands from the top of the piston. This keeps the rings a little further away from the extra heat that nitrous produces in the cylinder.
Old Aug 9, 2002 | 10:06 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Since both nitrous and S/C pistons are forged, you could use nitrous pistons in a S/C application if, and that is a big if, they give an low enough compression level. The biggest difference is what Big Mike said, " Nitrous pistons are designed to have lower ringlands from the top of the piston".
Old Aug 9, 2002 | 10:32 AM
CHRISPY's Avatar
In a nitrous application the ring gap and type are different as well to prevent "Butting" of the rings under spray.
Affects NA performance very slighty
Cheers,
Chris
Old Aug 9, 2002 | 06:39 PM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ls1290:
<strong>Since both nitrous and S/C pistons are forged, you could use nitrous pistons in a S/C application if, and that is a big if, they give an low enough compression level. The biggest difference is what Big Mike said, " Nitrous pistons are designed to have lower ringlands from the top of the piston".</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Cool, so it sounds like rings are definately a big difference. But what about the shape of the piston top? I'm curious how that would affect the CR. Thanks!
