HELP ME OUT!
Old Aug 10, 2002 | 02:22 AM
Dane 98 Bird's Avatar
Default HELP ME OUT!
Here recently when I am accelerating and I am at about 5200-5400 rpms (not for sure)my car wants to hesitate for a split second. I have know idea what it could be, so I went to my mechanic and he is not for sure either, he said start maybe by replacing the Crankshaft Poistion Sensor, then maybe if that is not it, it could be a coil pack. He said his 00 WS6 had the same problem, because he accidently downshifted from 6th to 2nd and he bent 5 rods, but in my case no tinging coming from the motor. Also when we had the scanner hooked up to it my coolant temp. was reading 200-203 degrees, is that high. I have a 160 degree thermostat. Also I haven't been able to run my Air Conditioner at full blast cause my car is wanting to overheat. I need serious help, so if there is any good knowledge or info out there please send it my way. I am in the military and don't get paid ~~~ that much so hopefully my problems aren't expensive. Thanks Dane
Old Aug 10, 2002 | 03:18 AM
Default Re: HELP ME OUT!
ttt
Old Aug 10, 2002 | 01:34 PM
ttt
