Building bottom end...
Old Aug 10, 2002 | 01:24 PM
Gag_Halfront's Avatar
Default Building bottom end...
I believe I already know the answer (and it is obvious) but I still have to ask...
In a brand new set of bearings and freshly machined block and crank, should the thrust bearing ever cause the crank to not just drop into place? IE: Should the sides of the thrust bearing and the crankshaft ever be such a tight fit that the crank doesn't just drop in and sit where it is supposed to? I have an engine I'm putting together and I think I have the wrong thrust bearing in the kit.
Old Aug 10, 2002 | 01:32 PM
Fireball's Avatar
Default Re: Building bottom end...
crank should drop right in and spin very freely
Old Aug 10, 2002 | 01:34 PM
*sigh*
That's precisely what I thought. This _CAN'T_ be the right thrust bearing.
All the other bearings are fine. It's just the one that's a problem. If I'm fast, maybe I can get to the parts store before they close. :/
